whats the DA??
Here you go. In 2 week I'll be spraying water meth. Fingers crossed for 12'shttp://www.dragtimes.com/da-density-altitude-calculator.php
I can assume my vehicle isn't stock (as I had thought it was), but my best run was with tires fully inflated a 13.3 @106.95 at gateway international raceway. I have done a few highway pulls with my buddy and his SRT-8 jeep (modded with headers, CAI, and tune). He at gateway same night turned a 12.6, and I put a car and half on him at a 20-120 pull. I spun off the line and chirped second pretty bad :/. Bout 60-65 degrees when I ran at track.
This was against a procharged Crown Victoria.
You could be stock. I ran a 13.18 stock not too long after getting mine and I really couldn't/can't drive that great. Elevation plays a big part.
You only agree that I can't drive great.I agree with this. I ran 13.1 @ 107 with my first truck stock. This was at Atco which had a negative DA that day.
Side note I watched a buddy run a 12.9 with a bone stock one down to the paper filter. I'd recommend never buying that one as he drove it balls to the wall every time the red button was pushed.
About all I know is black and was traded in at national dodge in Jacksonville nc in 2012 I believe. Clutch went out on first test drive and power steering while moving it on lot.I don't agree with you not being a great driver, your stock time is impressive.
Can I get more information on this truck so I make sure I don't buy it?![]()
I can assume my vehicle isn't stock (as I had thought it was), but my best run was with tires fully inflated a 13.3 @106.95 at gateway international raceway. I have done a few highway pulls with my buddy and his SRT-8 jeep (modded with headers, CAI, and tune). He at gateway same night turned a 12.6, and I put a half car on him at a 20-120 pull. I spun off the line and chirped second pretty bad :/. Bout 60-65 degrees when I ran at track.
Yeah mine only had the Pirelli's on it at stock pressure.... I do have a set of 17's off of a Durango though that I'm debating on getting radials forThis was in a stock truck minus the DR's. Was also my very first time at the track. http://www.vtcoa.com/forums/f11/first-time-track-54374/
I'd test fit before buying. I know aftermarket ones clear but doesn't mean a stock Mopar rim will. Mine barely clear. In fact the stick on wheel weights got peeled off by drag radials on my first pass with them. Went to static balance after that.Yeah mine only had the Pirelli's on it at stock pressure.... I do have a set of 17's off of a Durango though that I'm debating on getting radials for![]()
How wide are those Durango rims??
