The Reaper QC build thread
BAD SNAKE
DC/MD/VA Area
So it has begun. We found a nice Qc to make into a killer family machine since we have out grown the Bad Snake
I got it home and spent a few days cleaning the paint, and swapping over some of my carbon fiber stuff stuff from the Rc
I sold the Oem bed cover, its not really my style.
I removed all the badges from the truck but the left the viper powered on the oem hood.
I installed new head light and fog lights.
I swapped over my other grill to see what it would look like.
then i swapped the some black honeycomb mesh into the factory red grill
When you swap a rc rear end in to a QC and use the QC drive shaft you will need a 1350/1410 universal joint
With some help of Mr hunt and Mr Zury and joe , we did the rear c notch, rear brake line bracket relocation, rc rear end shock mount tabs, and a few other things
I cut off the oem upper control arm mounts so i could install the Michigan metal work taller uca mounts that are offset away from the headers.
I got some different front springs made up at a local place with a spring rate of 1100 compared to 695-697ish stock springs
Bad Snake
Hello Badsnake, I noticed you have a Hotchkis Rear sway bar. Can you provide me with a part number on that part as I would like to add that to my truck. Thanks again.
