WHAT TO LOOK FOR WHEN BUYING A RAM SRT-10
Discussion in 'General Discussion' started by trussman, Oct 27, 2015.
Car Parts
  1. trussman
    trussman Active Member
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    Let's make a list for newbies and maybe make it a sticky if not one already somewhere????
    Maybe quote and add to the list for items that seem to repeat often.
    Oil cooler lines
    Power steering lines
    Loose harmonic balancer bolt(typically 04's)
    Idler/Tensioner pulleys(due to age now)
  2. lightningKILLER
    lightningKILLER Full Access Member
    1,565
    4
    Jul 19, 2006
    Indian Head, MD
    Nice call.
    After 10 plus years,
    Rust
    Drivers seat leather condition
    Transmission (no reverse, or reverse popping out)
    Oil filter whine (use viper only)
    Clutch
    THEWELSHM likes this.
  3. Wetdawg
    Wetdawg Full Access Member
    55
    Oct 14, 2015
    Hotlanta
    Look for forward right inner brake caliper for signs of overheating. For some reason The right front locks up.
  4. VPRPWRD
    10,836
    10
    Mar 28, 2012
    PA
    More common on 05/06 4 piston calipers.
  5. trussman
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    I was wondering that.
  6. earl lee
    earl lee Full Access Member
    613
    Jul 12, 2006
    Stone Mtn, GA
    Check for leaking power steering and oil lines. Its not the end of the world if they are leaking it just means they need to be replace before they completely go south.
  7. trussman
    4,043
    7
    Aug 14, 2007
    Jacksonville, NC
    As stated in original post.....
  8. 6speedquadcab
    3,132
    37
    Nov 11, 2014
    South Bay
    Body lines and seams. Make sure they have the correct gap all around as bigger or smaller gaps may indicate body damage in the past. Some people are honest about it, others will tell you it's never been in any kind of accident yet the body lines don't match up.
  9. Frosty05
    Frosty05 Full Access Member
    279
    Jan 22, 2014
    Joliet, IL
    After my experience, i would recommend plugging in an OBDII scanner and checking that the readiness monitors are/will set.
    For us poor souls in emissions states having a couple "not ready"'s can lead to some serious aggravation. Especially since it's over $1k for a new pcm.
  10. Viperguy
    Viperguy Full Access Member
    22
    Apr 20, 2014
    Check all brake calipers for over heating. I've had both front seize on me. Pretty costly. I ended up just buying all brand new calipers and upgrading to all slotted and drilled ebc rotors.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  11. armykyle1
    armykyle1 New Member
    15
    Feb 28, 2016
    Gulfcoast MS
    Does anyone else have something to add to this? I'm looking to pick up an 05 RC with navi this week. I'm waiting on interior pics and some better exterior pics, but it looks good so far. The truck has 115k on it, a little more than I like. But it's an excellent price. Mods are, k&n intake, borla cat back, center force clutch, fidanza flywheel and a tune.
    If this post needs to moved, I understand. I didn't know where else to post this.
  12. C-Note
    C-Note Full Access Member
    78
    2
    Nov 29, 2014
    As in all Dodge trucks of the era make sure that the heater is directing air to the proper vent. If not your blend doors may be broken and you have to pull the dash to fix it!
    VIPR PWR and THEWELSHM like this.
  13. 505'sFastestViper.
    505'sFastestViper. Full Access Member
    13,813
    Apr 26, 2007
    Farmington, N.M.
    Hole in side of block
  14. beastmode1
    beastmode1 Full Access Member
    580
    368
    Oct 2, 2014
    Denver, CO
    Also make sure all the recalls like the Airbag have been done. They should be no charge at dealer with the recalls.
  15. beastmode1
    580
    368
    Oct 2, 2014
    Denver, CO
    While on this, did any members receive a new recall notice CAMPAIGN # R25 /15v-313
    CDJR S43? That is what I got will check with dealer on this one as I thought all my recall repairs were up to date.
  16. tomdragoo
    tomdragoo Full Access Member
    33
    Dec 28, 2017
    I am the proud owner of a SRT 10 with the Paxton supercharger know if you 2000.I thought I did all my research well search for six months. Looking at this truck that truck everywhere truck truck evening away.! What advice can you give me as far as a bullet proof point system. Yes I have taken it apart six times already every time I pull back the other. I found something new. This last time was missing bolt space or bracket tree. I.e. one space or being larger than the smaller versions. Then I noticed that was supposed to go on the supercharger itself missing three of them so. I know it’s probably a board but it’s a mind headache menage a trois I’m having with this truck! Where we can do helps thanks[​IMG][​IMG][​IMG]
  17. mopar-or-no-car
    mopar-or-no-car Full Access Member
    3,086
    Sep 18, 2012
    North West Ohio
    Do you can speak in english?
  18. unacLe
    unacLe Has Left the Room - Banned from VTCOA!
    11
    Oct 25, 2018
    Haiti
    WHAT TO LOOK FOR WHEN BUYING A RAM SRT 10
    can someone do up a thread with what to look for in an fto and sticky it?
  19. ViperJeff
    37,324
    1,466
    Idaho
    No.
    :damnmate:
  20. VIPR PWR
    7,585
    2,942
    Jun 12, 2007
    FL
    Brake pads and tires
