driveline rattle at idle
Discussion in 'General Discussion' started by 505, Feb 6, 2019.
Car Parts
  1. 505
    505 Full Access Member
    79
    42
    Sep 7, 2018
    Orlando
    This is new for this truck. After driving the truck up to Deland and back last night - I bring it in - and clearly notice a light rattling sound under the drivers side. This is parked idling in neutral. Push the clutch in - rattle goes away. Let clutch out in gear - rattle goes away. Leave it idling in neutral with clutch out - rattle is there. Suspect I'm going to need to figure out what this is. Any input or guidance? Greatly appreciated.
    update - this morning, start the truck cold - no noise. nothing. so it's heat related.
  2. rottenronnie
    4,177
    2,149
    Jul 4, 2006
    Calgary, Alberta
    Release bearing (?)
  3. Slitherbeast
    2,283
    35
    Sep 10, 2007
    Alberta
    Do you have the centerforce clutch? They are known to lose parts......
  4. 505
    79
    42
    Sep 7, 2018
    Orlando
    IDK. I'm not the original owner. It doesn't do it cold. Only warm.
  5. THEWELSHM
    THEWELSHM Well-Known Member Supporting Member
    2,457
    82
    Aug 29, 2008
    Brandon Florida
    yep, when it warms up mate... We call it the throw out bearing:) Either way someone is pulling a tranny....
    thewelshm
    Far2Quik likes this.
  6. shorty
    shorty Full Access Member
    2,054
    36
    Sep 1, 2012
    Emory, Texas
    This is the only sight left where one can use the word "TRANNY" without getting hit with a purse.
  7. Barraza
    Barraza Full Access Member
    44
    Aug 4, 2013
    Albuquerque nm
    If it has if it has stock exhaust manifold check the shield mine broke right at the bolt that holds it down. Mine did the same.
  8. Rjgjr886
    Rjgjr886 New Member
    2
    Oct 17, 2016
    Hey I am in Orlando if you want bring it by and we can look at it ok
    THEWELSHM likes this.
  9. 505
    79
    42
    Sep 7, 2018
    Orlando
    it's got long tubes on it. the sound goes away when the clutch is depressed. I'm gonna let it rattle for a while until it gets worse. I'm the only one who hears it. What's odd (I think) is it's got an aftermarket trans in it (Tranzilla). So, I'm thinking, well hell, if the previous owner swapped the trans somewhere along the line - wouldn't they have done the clutch and TO bearing at that time? Perhaps not.
