Brakes
Discussion in 'General Discussion' started by Bobby S, Mar 14, 2019.
Car Parts
  1. Bobby S
    Bobby S Full Access Member
    45
    Sep 21, 2012
    Old Bridge NJ
    Any brakes out there better than stock. Seems to always squeak when braking.
  2. beastmode1
    beastmode1 Full Access Member
    580
    368
    Oct 2, 2014
    Denver, CO
    Hello I use Evolution semi metallic pads on Bmode no squeak and she stops on the dime. These trucks are heavy so my dealer recommended me to use those. You can find them on ebay.
  3. Michael from the U.K.
    Michael from the U.K. Active Member Supporting Member
    352
    42
    May 22, 2006
    Berkshire in England
    EBC have a range of pads/rotors for our trucks,I use yellows stuff with no complaints.
    GSJake likes this.
  4. beastmode1
    580
    368
    Oct 2, 2014
    Denver, CO
    I am also putting them on my Toyota Tundra Platinum. Alot better than the factory ceramics that I go through fast. Price wise they are comparable.
  5. POWERBRAKEBOB
    POWERBRAKEBOB New Member
    5
    Oct 7, 2014
    The brakes squeal because the Phenolic pistons in the calipers swell tight in the bores, not releasing, and causing the pads to drag forever against the rotors, burning them. There is no "magic pad" . I Used steel pistons to replace the plastic phenolics, and they release instantly. An added benefit is the freed up rotors add 1-3 MPG.
  6. beastmode1
    580
    368
    Oct 2, 2014
    Denver, CO
    Great point.
  7. Slitherbeast
    2,283
    35
    Sep 10, 2007
    Alberta
    All GOOD Brake squeal...... Best thing to do is USE THEM!.... Pussy footing the brake will glaze them over and they will squeal..... Stop HARD and they won't squeal... :)
  8. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
  9. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    Where did you get the steel pistons .. mines a 05 4 pistons .
