AMS3
Does anyone have advise to fix frozen recline/incline levers? Both front seats levers are frozen.
Maybe wd40 will do they trick and lube things up with the other parts not working .. May some of that spray on lithium grease ?Does anyone have advise to fix frozen recline/incline levers? Both front seats levers are frozen.
Use Prolong Lubricant will loosen up the rust pretty quickly. I hope this helps.Does anyone have advise to fix frozen recline/incline levers? Both front seats levers are frozen.
I appreciate the responses. Like you, I have yet to tear into the seats, the heat outside is crazy! I do have a few other questions though. Did you notice a difference in performance by dropping the thermostat to 170°? I'm also looking at the BBK throttle body and also want to install a ram air intake. Do you know if they will mate up to each other?
