To Clean or Not To Clean
quiller303
Hi All,
2 year owner of a 06 QC. Not knowing the service history of the truck, I changed out all the fluids, new plugs, coils, leads, brakes, rotors, belt, etc. One thing I didn't replace were the fuel injectors. Truck runs well but with 65K on the odometer I am considering sending them out to be flow tested and cleaned. I know that if all 10 injectors are not flowing within a few percentage points of each other, I may be losing some performance. I would be interested to know what you guys think of this and whether it is not worth the effort and expense.
I would also like to know if I should change out the O2 sensors for the same reason.
Thanks!
2 easy things I did to my QC10 that I thought made a noticeable improvement in drivability and throttle response was - I had the dealer service the transmission and tighten the bands. And I switched to 20-50 engine oil. The trans shifted crisper and more like it was when new. The bands on my truck were definitely out. And I think (but can't prove) that the thicker oil keeps the lifters pumped up at low RPM. It had a little more giddy up off idle.
50-60,000 miles recommended. Mine went out before that so I change them every 30K
I've never used injector cleaner on anything, nor have I had them "power cleaned" or whatever you like to call it. There seems to be enough detergent in name brand gasolines to keep them working properly.
I had mine flowed though, as they put out considerably more than stock ones do so I jammed the richest ones in the back.
I drove around for several thousand kilometers then whipped the heads off as a borescope was inconclusive. Couldn't ask for a better burn pattern.
Just been for a skid, I am getting a slight flutter at real light throttle and then a check engine light so I guess a tune up is going to be happening real soon.
I have 68k on the clock. Feels like a dodgy plug or injector No Scan tool yet. Had one for my jeep but it not work on truck:(
Key on-off-on-off-ON to access On Board Diagnostics.
Codes displayed will help narrow down issues.
P0207 came up. Looks like #7 injector/wiring issue. I can work with that
Yes, the zero weight oil is/was to provide lifter collapse at idle to pass emissions.
Oh dear. swapped injector to #5. Cleared code then went for a drive. It is fine until in 30mph area as the throttle is so light it stutters then throws the light.
I was an hour visiting a friend and it cleared itself when I left and was fine most of way home when using a bit more throttle until back on super light throttle then ping it came on again. It maybe a crappy tune as the performance shop in Wellington where it was tuned on the dyno has closed down. The dyno sheet I have been given reads like crap and shows it falling over at 5000rpm. Smells like a shady job to me, no AFR either. There is definitely some work needed there.
I had a engine light come on about a month ago, and tried the key on, key off trick. Where does it show the code? In the dash, the overhead???
The stutter (could be too much advance in the tune) and/or the throttle position sensor; I've had those go bad without tripping a code. And/or a vacuum leak.
