Not a bad quarantine day
Srt10650
Not a bad quarantine day when you have 2 SRT10 trucks at home. My buddy drop off his 04 SRT10 RC for some maintenance and mods. He just got it so he wanted me to go through it, it’s an 04 RC with 83k miles. The thing I don’t like is he mentioned it has had 10 previous owners. He had the t56 rebuilt already and the front end suspension(lower ball joints, upper control arm/ball joints, endlinks, and sway bar bushings from what I seen. Replaced valve cover gaskets(washed/cleaned foam and inside of the valve covers), replaced throttle body gasket(cleaned tb), replaced the Ngk spark plugs with good ole Champions , replaced hood lifts supports(stocks were done, had to used vise grips to hold the hood up) wires were good for now(previous owners had Taylor wires with zip ties), removed center seat stock subwoofer amp(he has an aftermarket system and doesn’t use the amp) for more storage space, added a Taylor throttle body spacer, and a Grant products steering wheel. Below are some pictures.
More pictures.
More pictures
Hey that's great. Wanna do some work on mine, you could drop by and pick it up.:D
Seriously tho it is nice tending to our beasts.
Sure, are you located near the Bay Area in California? Yea it is, next thing on the to do is oil cooler line, oil change/filter(with viper filter, it has the M090 right now) and differential fluid/gasket(it’s been leaking).
Hahaha I am a long way way across a mighty ocean. Bottom of the world
Hey but keep up the good work. I can enjoy someone elses truck getting improved while mine is resting in the garage
Cleaned up real nice!
That's the second post (other on Facebook) about someone with a TB spacer. Correct me if I am wrong but I thought those were more of a gimmick?
His bill will be pretty hefty when you are done unless you guys go way back as friendlies lol!!!
FYI if you need to source parts, X2 builders are the way to go Scott is pretty helpful locating difficult to find Ram SRT10 parts.
i see it as more a personal preference, your going to get both opinions. Some say butt dyno approves, some say don’t waste your time and send them the money. I’ve seen some dynos and they do pick up a few hps (I’ve seen from 1-5hp). Some don’t pick up any. Just really depends on personal preference, dyno, and engine. Some engines don’t like tb spacers too. That’s just my opinion though.
lol, pretty good friend. Just in parts price is $462.98, not including anti seize, dielectric grease, degreaser, wd40, brakes parts cleaner, and my labor. But for sure way cheaper than any shop or dealership.
I emailed them once, never heard back from them. So I never tired them again, I’m big on customer service and they failed me that time. To me(my opinion) their prices are really expensive, I get it they don’t make the trucks anymore. But man those prices!
