Transmisson Question
Discussion in 'New Members Section' started by AMS3, Apr 15, 2021.
  1. AMS3
    AMS3 Well-Known Member
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    Ok guys, I'm getting ready to have my tranny rebuilt at the end of the month. I need to know which automatic tranny we have, the diesel or gas version so that I can relay that to the tranny shop.
    Kiwi SRT10 likes this.
  2. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Our transmission is a 48RE
    SAME transmission for diesel or gas. Even the valve body has the same part number.
    Kiwi SRT10 and Srt10650 like this.
  3. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Strongly suggest using DEXRON VI instead of ATF+4
    But your tranny shop will likely cover themselves and say IT'S NOT APPROVED FOR THIS TRANSMISSION!!!
    Maxville and Kiwi SRT10 like this.
  4. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    What's the difference in the fluid? I know it has ATF+4 right now. Also, they will install a shift kit as part of the standard rebuild. What other fairly inexpensive enhancements can I have added, keeping those to about $300 above the rebuild cost.
  5. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    The +4 is a slipping agent as the shudder created by the fluid before the plus 4 was setting off the knock sensors in the minivans because of shudder when going around corners.
    From your perspective you don't want a slipping agent in your transmission fluid. That's what shift kits reduce- slip between shifts.
    And it doesn't stink like ATF + 4
  6. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Up to you man.
    Glad to see its finally getting repaired.
    Hopefully they will do a good flush on the convertor OR if is in your budget a new convertor in the 2600 to 2800 stall range.
  7. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Go have some fun!
  8. Srt10650
    Srt10650 Full Access Member
    360
    305
    Sep 30, 2016
    Some relatively less expensive items and worth the money would be a billet accumulator piston, billet 2nd gear servo kit, billet/heavy duty kick down band strut, billet anchor, billet lever, GM style governor pressure sensor, upgraded metal pressure transducer(I believe the one I bought is for a 46re that works for the 48re). There might be other things I’m forgetting, but these things are definitely a good start. Big money items would be like a billet input and a good torque converter.
  9. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Sorry AMS3, I didn't thoroughly read your post.
    Yes indeed ! (as above).
    The "Gold Can" Transducer for a 1999 Dodge Diesel is an excellent choice.
    The Solenoid from a 4L80E (GM) transmission is also a good pick with larger ports and screens.
    THAT is the problem with our OEM Solenoids (tiny ports and screens) and what makes them susceptible to plugging and transmission death.
    The thing to watch for is interference when mounting the GM solenoid as the bracket used interferes with the body OF the Valve body and may prevent the Solenoid from sealing fully when installed. As in: You may think you have the bracket tight but it is actually kind of twisted instead of mounting on the flat and sealing (hard to explain but relatively easy to spot if you are paying attention).
    Kiwi SRT10, AMS3 and Srt10650 like this.
  10. butch2000
    butch2000 Member
    18
    27
    Mar 18, 2021
    any experienced tranny shop should not be relying on you ? to tell them what tranny you have ?? if they are ? I would rethink the shop's ability to build you a correct tranny ?
  11. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    The shop rebuilds the torque converter, plus the pump and valve body. I researched the stall converter, a bit out of my price range. I'm already looking at around $3800 with the shift kit.
  12. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    They know what I have, it was for my own information. This shop is well known and has nothing but accolades from everyone who's taken their vehicle to them, so I feel confident. If they F it up, they get to fix/replace it.
  13. butch2000
    butch2000 Member
    18
    27
    Mar 18, 2021
    ok
    AMS3 likes this.
  14. Kiwi SRT10
    1,012
    1,119
    Dec 16, 2019
    New Zealand
    I am excited for you. You will think it is a different vehicle and it will be so much quicker and responsive.
    Be even faster with an exhaust like mine:)
    AMS3 likes this.
  15. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    So all these years I thought a super charger made the difference, not exhaust. Who knew...:D
  16. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    Quick question. Does anyone know if I need to add an extra trans cooler, or is the stock one good enough? My truck goes to the shop on Monday.
  17. butch2000
    butch2000 Member
    18
    27
    Mar 18, 2021
    depends on what you will use it for ?? towing etc ?
  18. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Because the quad cabs came with a trailer hitch, I'm assuming the cooler is also up to the task.
    Srt10650 and AMS3 like this.
  19. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    No, don't plan to tow anything.
  20. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    You have a QC right? Did you add one for the hp you have?
