Power Steering Hoses
Discussion in 'New Members Section' started by AMS3, Nov 30, 2021.
  1. AMS3
    AMS3 Well-Known Member
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    Are the JSTSVP power steering hoses any good?
  2. Modern Barbarian
    Modern Barbarian Active Member Supporting Member
    105
    139
    Sep 16, 2021
    they are. that and the oil cooler lines are on my truck. both high quality.
    The power steering line adapter started leaking a few months ago and a quick oring change and it quit. oring was less than a dollar.
    Srt10650 and AMS3 like this.
  3. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    Thank you for the response. Do I need to order the steering rack bushings as well? Not sure what those are for.
  4. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    I did not have luck with them.
    They leaked badly at the fitting and changed the feel of the steering.
    They failed a quick left to right steering "jerk" test as the capacity of the hoses is less than oem.
    I took the oem hoses to an industrial shop instead.
    Some guys like the kit.
    I did not.
    AMS3 likes this.
  5. Modern Barbarian
    105
    139
    Sep 16, 2021
    I didn't do the install of them on this truck, they came on it when I bought them used. I only did the O-ring repair. so not sure about the rack bushings.
    AMS3 likes this.
  6. AMS3
    1,068
    769
    Aug 8, 2019
    Savannah Ga
    So did it feel like the steering wheel was fighting you? One other question, what does, and where do the steering bushings go that JTSVP offers?
  7. Bad Azp Performance
    Bad Azp Performance Member
    83
    91
    Nov 9, 2021
    Las Vegas Nevada
    The bushings are where the rack mounts to the truck.
    Rubber bushings deteriorate over time and result in slop in steering
    AMS3 and Srt10650 like this.
  8. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    No, not exactly. The steering felt like it was lighter (more assisted by hydraulics) with the kit.
    What I didn't like was it would bind on a fast left to right or right to left jerk on the wheel.
    AMS3 likes this.
