Front Lower Control Arm - Where do you find the stamped part number?
Absolutely!!
As many of you know I want to convert my lowered truck back to factory height.
My question is if you buy used front lower control arms how do you actually know you are getting a factory SRT-10 front lower control arm?
I have researched many topics here on the forum and read on one thread saying the Ram 2500 front lower control arms look identical to the SRT-10 arms and they recommend using those. Another thread said the SRT-10 are special, and a Ram 2500 might work, but is not correct (not sure what the difference is).
Is there a part number stamped somewhere on the arms so I can verify I am getting true SRT-10 part? I hate spending the time & effort by not putting in actual SRT-10 parts. So many scammers out there just trying to protect myself.
Check the build sheet for your truck(Viper Registry). Most of the parts are standard 1500 Ram parts. The list of special SRT-10 parts is quite short and mainly superficial exterior and interior parts. Except for the obvious engine trans wheels etc. If you are concerned then cross reference on Rockauto between 5.7 and 8.3 weed out the 4wd parts and bingo. My front suspension kit is listed in both 8.3 and 5.7
Why do you need to change control arms? It is only the springs that are shorter. Just loosen the bushings bolts and retighten them when your truck is at it's new normal ride height, so you don't risk tearing the bushes.
Here is my build sheet. There is the list of special items. Springs, shocks, swaybars, brakes, the rest is standard 1500 truck
Registry Number: VTR-2915
Equipment Listing
VIN 3D7HA16H14G170216
Vehicle Description 2004 DODGE RAM 1500 REG. CAB PICKUP
Monotone Paint
136 Amp Alternator
Front Height Adjust Shoulder Belts
Passenger Air Bag On/Off Switch
Next Gen Multistage Front Air Bags**
Floor Covering Carpet
Passenger Assist Handle
Behind the Seat Storage / Bin
Tinted Glass Windows
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
Remote Keyless Entry
Dash Liner Insulation
Floor Tunnel Insulation
Route 77 - UP, Mesquite, TX
Instrument Cluster w/Tach
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
Glove Box Lamp
STANDARD EQUIPMENT
Halogen Headlamps
Cargo Lamp
Front License Plate Bracket
Dodge Badge
Removable Tailgate w/Caliper Latches
26 Gallon Fuel Tank
Speed Control
Black Clear Coat
Tilt Steering Column
Tire Carrier Winch
Pickup Box
Trailer Tow w/4-Pin Connector Wiring
Build To U.S. Mkt. Specifications
GVW Rating - 6750#
U.S. Dealer Retail
Zone 63-Dallas
Two Wheel Drive (2WD)/(4X2)
6 FT. Cargo Box
Regular Cab
1500 Series
DR-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
Texas Ship to State Code
Texas Sold to State Code
Leather Seats w/Perforated Suede
Dark Slate Gray
OPTIONAL EQUIPMENT
Light Group
SRT Group
Security Group
8.3L Eng(EWC)/6Spd M/T (DEC)
750 Amp Maintenance Free Battery
Anti-Lock 4-Wheel Disc Perf Brakes
40/20/40 Split Bench Seat
Front Floor Mats
Front Center Seat Cushion Storage
O/Head Console w/Trip Computer/UGDO
All Manual Transmissions
6-Speed Manual TREMEC Transmission
4.10 Rear Axle Ratio
200MM Rear Axle
Anti-Spin Differential Rear Axle
8.3L V10 SFI Engine
Rear Sliding Window
Sun Visors w/Illum Vanity Mirrors
Rear View Auto Dim Mirror
All Vehicles W/Power Mirrors
Satin Silver Lock Knobs
Sentry Key Theft Deterrent System
Air Cond'ing w/Dual Zone Temp Cntrl
Instr. Panel Sport Bezel
160 MPH Primary Speedometer
Black Clear Coat - Molding - Sill
Ash Tray Lamp
Front Dome w/On/Off Switch Lamp
Underhood Lamp
Fog Lamps
Security Alarm
Body Color Grille
Hood Power Bulge
Body Color Front Fascia
Body Color Rear Fascia
Ram SRT10 Badge
SRT10 Badge
Viper Powered Badge
Rear Bodycolor Spoiler
50 State Emissions
Federal HDV1, Cal. MDV 1 ULEV II
Bright Exhaust Tip
Dual Rear Exhaust w/Bright Tips
Maximum Duty Engine Cooling
Black Clear Coat
All Radio Equipped Vehicles
AM/FM CD 6-Disc Radio
8 Infinity Speakers w/Subwoofer
Fixed Long Mast Antenna
508 Watt Amplifier
Steering Wheel Mounted Audio Ctrls
Performance Steering
Leather Wrapped Steering Wheel
Front Perf Tuned Shock Absorbers
Rear Perf Tuned Shock Absorbers
Rear Perf Tuned Stabilizer Bar
Front Perf Tuned Stabilizer Bar
Compact Spare Tire
P285/40R22 BSW All Season Tires
Pirelli Brand Tires
20" Steel Spare Wheel
All Aluminum Wheels
Center Hub
22X10.0 Aluminum Polished Wheels
Power Adjustable Pedals
Bright Pedals
Hurst Shifter
Basic Owner's Manual
Manuf Statement of Origin
2 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
FAM:DR TRACKING: 30910M09AA MY:2004
FAM:DR TRACKING: 204SRT01AS MY:2004
Customer Preferred Package 2TS
Customer Preferred Package 29S
Distribution Services Tracking
Waterbase Paint
BusinessLink Inventory
Paint Order Code
How are you coming along with the part number quest for the control arms?
I've used X2 for several items, including the rear spoiler.
What did the spoilers cost at X2.. I ma need a sledgehammer to get mine off !
Hahahaha!
On a serious note ,, I’m about to decide to try the drivers side brakes finally .. Hope I up for it ,, the doctor wound at least appears almost clear .. I’ll see if there s a sticker uh oh I mean a uh oh something that looks like a part number :cool: to f not I’ll just get some letter and number punches and add one hahaha !
We'll be waiting! Hahahaha
It appears mine doesn’t have a part number on the lower comtrol or the upper control arms .. or did it on the lower , see the sticker on last pic ! Faded and washed away numbers !!
That leaves only 1 option IMO … WIFEY TO THE RESCUE since the Queen has such low mileage it could very well have a readable intact sticker … @2005ViperRam
IMG_0897.jpegIMG_0898.jpegIMG_0899.jpegIMG_0900.jpegIMG_0901.jpegIMG_0893.jpegIMG_0894.jpegIMG_0896.jpeg
Thinking tomorrow but will see how I feel
View attachment 66127View attachment 66128View attachment 66129View attachment 66130View attachment 66131View attachment 66133View attachment 66134View attachment 66132
Ha!!!! A sticker, I knew it!!
If I ever see that part I will get the r number hahahaha!
I think they are standard Ram 1500???
Either way the online parts manual has the OEM part number (s) in it so the trick is finding oem if one wants oem lol
The sticker on mine at least is easy to see on the bottom side of the control arm … heck if you have a self stick taking a pic should be a breeze .. or just sticking your arm under the truck , sim and click hahaha
