Surging
It seems like you need a 3rd arm for this but with a little creativity, you don't.
Disconnect the TPS plug.
Set your multimeter to Ohm.
Use the Red Lead on the center pin and the black on either outside pin.
Then using a large-blade screwdriver, turn it slowly one way and then back slowly.
It should register from 100 at rest to 225, wide open. Some aftermarket units may register 250 or more. That doesn't appear to bother the ECU. The thing to watch for is a nice linear/smooth progression up and down as it is turned. If it is smooth and hits the 225 value (or so), you have a winner.
Speaking of screwdrivers...
You can also try this: There is a small screw ( as you likely know ) on your throttle body that is kinda/sorta a curb-idle adjustment. You could try SMALL adjustments either up or down, as I seem to remember after mine was ported, it required a small tweak to prevent surging. Once properly set, you shouldn't have to touch it again.
Good luck.
Good luck.
The BBK throttle bodies had a surge and would slightly stick raising the RPMS .. Mine did .. and messed with the screw and it cleared up the surging ,, but I still once in a while get a slight stick on the throttle .. I just tap the gas peddle and it goes away till the next time lol .
no codes no CEL
Vacuum leaks can be other than the hoses .. my first vacuum leak was the hose that connected to the cruise control unit .. they can be at the intake manifold, throttle body, loose bolts blah blah .. did you try spraying carb cleaner around areas of the engine to see if you get a rpm change and a vacuum leak .. clean the throttle body incase corrosion occurs or carbon build up has happened at the butterflies ,,, Worn bushings or throttle shafts ! Bad plug , wires , plug gap ! The sensors are probably the most pain in the ask to find any problems especially if no codes are thrown ..
thank you for comments. it appears that the small 1/8"? vacuum line from firewall to cruise control (under battery tray) is broken at the junction on the firewall. Orlando Dodge laughed when I asked for a part number. Now what? Can we make vacuum lines? ugh.
If i remember correctly and we’re talking about the same hose .. mine was long enough at the connection to cut off the split hose at the connection and reconnect it and later used a standard hose from the parts store .
Post up a pic !
This I believe s how I fixed it in the pic … it happened a long time ago..
If all else fails the part number may be in the service manual posted online in a thread here
Looks like that fix works!! Good call on the troubleshooting ideas
