Low oil psi
Drogi77
Getting low oil pressure at idle. 15 to 25 at 200 degrees. Cold start is 75 to 80 psi. Compression is good on all cylinders. Truck has 140000 miles on it. I do get ticking sound on it at idle, don't know if lifters or valve train. Want to change oil pressure relief valve but can't find one. Any help will be appreciated.
Check out this thread
Yours appears to be within teason formthat kind of mileage ..
At idle what RPM are you getting .. it may he the reason for it getting a tapping noise as the lifters bleed down ..
Hahah! I just went theu that thread too (great minds) and this one makes sense
Its good info also !
Sometimes a new oil filter helps. Maybe worn bearings. 140k should get a medal for that distance without hand grenading. My truck has 79k on it and is now on 3rd engine. Last one still had hone marks in the bore
