replacing U-Joints question
Troy's QC SRT
Virginia
I need to replace mine (all of them) but I want to know the best way to go about doing it. Can I just press them out with a clamp and press in the new ones with the clamp or how do I need to do it? Also which ujoints should I get? Autozone has like 3 options....one that is greaseable and two that isn't....does anyone have a link that I can just buy them from or know which ones I should go with? I'm trying to get them changed out while my truck is down!
I believe the driveshaft is aluminum. Be careful! Or just take it to a shop and have them all changed to greaseable ones and get the assembly balanced ....just my opinion
I use a balljoint c-clamp to press them in and out and sometimes use of a hammer if needed to help. I prefer using the brute force heavy duty non greasable ujoints I destroyed a set of greasable ones on my 85 and had to replace the whole driveshaft.
I use an OTC 7249 to press them out. This method supports the yoke well.
Greasable or non? Well, I tend toward greasable for off-road where immersion is common - thought is that you could flush contaminants out with fresh grease. I use sealed (Spicer Life series) for onroad with the thought that the better seals these have will keep the bad stuff out and the good stuff in.
Good discussion here:
http://www.pirate4x4.com/tech/billavista/PR-shaft/index4.html
If you go greasable, most folks that pay attention will install the zerk part of the cross so it is in torsional compression for forward motion, not in tension.
Ok that's what I want to hear....what others out there are using. Obviously the 10 does not and never will go off roading but iv'e heard that greaseable u-joints were weaker so I was leaning towards solid
Two thngs about perceived strength differences:
1. I think it was more true in the past than with current premium joints.
2. I think it's also more true when installed with the zerk hole in torsional tension.
Another thing I forgot to mention - the greasables generally make a little bit of a mess as they force the excess grease out.
Thanks for the info a lot &arold....after reading I want to go with spicer's life series. Non-relubeable u-joints! Do you have a part# for them or where to order? Around how much am I looking at to replace them and do I reuse my factory c-clips when I press these in? I need to order them asap!
Occasionally the joints are held in with plastic that was melted and formed into a groove around the joint. Im not sure if ours are like this or not, but if they are they can be a real beatch to take apart without the proper tools or a press.
Sorry not to get back sooner...
5-801x is the 1410 series joint our trucks use. I bought a batch a while back, but don't remember where...
They come with new clips. Also have a little steel wool and a file to touch up any burrs on the yokes.
Google came up with
http://www.northerndrivetrain.com/pr...PI-5-801X.html
and lots more...
Thankfully not used on ours - just "old fashioned" c-clips on the ends of the caps.:congrats: But you are absolutely right about the biotch part!:dontknow:
Thanks alot Harold....I just ordered the U-joints in the link you posted....should have them in a few days!
