SRTHOR
05 RAM 1500 SRT 10 8 3L Viper Engine Manual Trans Rolling Chassis Full Frame 47K | eBay
This is a COMPLETE full frame rolling chassis which will include the following:
· Thoroughly tested 2005 Ram 1500 SRT-10 8.3L 505HP 500 CI V-10 Engine and T-56 manual transmission.
ONLY 47,000 ACTUAL MILES ON THIS SETUP
· The main fuel pump with fuel tank assemblies including the charcoal canister
· The aluminum heavy duty driveshaft is included as well
· Dana 60 4.56 gear ratio rear axle complete brake to brake
· Standard ABS-equipped brakes are fitted with new 15-inch rotors on the front brakes. Rear brakes are modified Ram Heavy Duty 14-inch rotors.
· Heavy duty painted red SRT-10 calipers
· Also included are Bilstein shock absorbers, with SRT-10 heavy duty performance-tuned springs
· 22-inch OEM "Viper-style" wheels with 305/40/ZR22 Pirreli Scorpion Zero in the front and rear.
· Engine Computer
· Pedals
· Complete dash pull out with speedometer, dash harness, both air bags, airbag module, radio, radio amplifier, radio bezel, engine start button and more
· Steering column with ignition and key
· Steering wheel
· Body harness with underhood harness and fusebox
· Brake booster and master cylinder
· Engine Computer
· Pedals
· Steering wheel
