06 owners, need a lil help
JTS VENOM PERFORMANCE
Preferred Vendor
SRT10 heaven
Having some brake lines made up for the 06 models, but they are completly different from the others.
The front brake line is mounted to the outter coil mount, or basically where the line goes thru the frame.
anyway if someone could I need the inside diameter of the hole the line goes thru, and the thickness of the metal also would be good.
It shouldnt be too bad, just remove the bolt holding the line, pull the line back and it should give enough room to take the measurements
thanks in advance:rock:
Uhhh... I'd like to help you but my truck is in the garage where it is currently 16 degrees. Can you wait until April?! :(
LOLLOL If I have to bro:D
Isa hopin somebody would take a lil, means a killer deal on the front set;)
Stinker you should buy another 05 and a 06.........................................then your problem would be solved:D :rock: ;) :elefant: :elefant:
Thanks Patrick:rock:
Dont worry bro, the 04-05 guys are gonna be pissed, the 06 front kits are gonna be cheap:p
There shouldnt be alot to them, plus they are short short short:D
not jumpin on your thread but wouldnt be a better idea to.........................just kiddin i have no good ideas!! stinker get it done..
Is this the line you are talking about?
Here's what I got; .716" diameter, .150" for thickness
May be is that the size of the hole in where the mounting part of the line goes thru?
and the thickness of the area it goes thru?
thanks bo:D
I wish I had a pic of the area, but no 06 in th stable:D
Roget that, it is the hole that the line goes through going out to the caliper.
Yeppers, now is that bracket welded to the frame? cant tell the pic is a lil dark:D
but is the .716 the inside diameter of the hole or the diameter of the part going thru it, cuz I need the actuall reading of the hole itself, the only way I can find to do a line is a different kind of fitting that will fit thru the hole:D
The bracket is welded to the frame and the bumpstop bracket. The .716 is the inside diameter of the hole.
Stinker said:
I got something warm I can put on ya shoulder:p
oh really....................i dont want to know.................hey hows the truck comin...............you have had plenty of time............................................................hey justin is doin a twin turbo setup for me
