06 srt10 draining battery overnight
Discussion in 'General Discussion' started by New2srt10, Jan 19, 2019.
  1. New2srt10
    New2srt10 Full Access Member
    8
    Aug 26, 2018
    Hey fellas, I have an 06 QC that will drain the battery overnight to the point that it will not start. I had the battery, alternator and starter all tested and all showed to be good. This has happen twice in about a 2 week period which is the strangest part lol. Any hints or suggestions would be a great help. Thanks guys.
  2. oldcolt
    2,654
    2
    Jul 14, 2008
    Calgary, AB
    Any non-stock wiring...stereo etc.?
  3. New2srt10
    8
    Aug 26, 2018
    It has some wiring of some kind that I just found around the drivers side headlight. Had a Schumacher trickle charger wired up to the battery but I have took all that off. I haven't got into the other bundle of wires around the headlight yet to see what all that is yet. Haven't done parasitic draw test on battery yet but she fired right up this morning and ran good.
  4. THEWELSHM
    THEWELSHM Active Member Supporting Member
    2,368
    2
    Aug 29, 2008
    Brandon Florida
    Mine was doing the same, it was the battery.( even though the test stated otherwise) The 4th Ive had under warranty:rock:
    thewelshm
  5. New2srt10
    8
    Aug 26, 2018
    Lol yeah if she does it again have to dig a bit deeper and maybe replace battery.
  6. Slitherbeast
    Slitherbeast Active Member Supporting Member
    2,236
    Sep 10, 2007
    Alberta
    First place to start..... Replace the battery. I thought I had some trouble one day .a while back. and spent days trying to Diagnose. It was the battery......
  7. Erobins
    Erobins Full Access Member
    83
    Aug 9, 2016
    Miami fl
    We all been there done that I suppose every days my truck would die replaced two batteries the shop thought the interstate vendor gave them a batch of bad batteries but I narrowed it down to the aftermarket dome light bulb 9 bucks later you know how the story ends :)
  8. 505
    505 Full Access Member
    37
    2
    Sep 7, 2018
    Orlando
    Well the beautiful thing is...if you swap the battery..and it still does it, at least you'll know... it ain't the battery. lol
  9. New2srt10
    8
    Aug 26, 2018
  10. unionmanofsteel
    unionmanofsteel Member
    555
    Sep 4, 2009
    Charleston, SC
    I had a similar problem. First I was told it was the alternator since i just purchased the battery. Then thought I had a draw turns out that the battery was bad after all.
