170 stat
I have no experience with the SCT. I have had the VEC from the beginning, and do not plan to change...it works well as it is, and since I am just an occasional driver of the truck...working well is fine.
I have noted that Sean Roe has moved toward the SCT for its flexibility.
I'll keep playing with the software in my spare time and documenting which features do what. I think SCT still need to do a bunch of developement on their tuner package. It's a bit frustrating with all the conflicting values in the software. According to them, they just have everything possible listed, not everything applicable. Trying to figure out what some of the values do using the 'cut and try' approach is time consuming for me.
DevilDawg3097 said:
Quote from stinker "ok , these are the ones I can get you a good deal on, but the 16927 is listed as a pusher fan but also look at the dual tornado, they are push pull and the 16824 is about the right size, but please do ssome measuring to make sure of the fits see which one will work for ya ",
http://www.derale.com/dual-rad-fan.html
16927 is what I am going to go with. After more researching it can be made a push or pull and my bad 4000 cfm.
you goin to be usin the ECM to controll the fans or a stand alone system with over ride switch?????
