68340GTS
Took many peoples advice here. Used Mobile 1 15-50. No more sewing machine noisy lifters and raised oil pressure 25# or 175 Kpa. (Damn metric system). Sounds like a completely different engine. Thanks for your help.
If I can last through winter before I need an oil change it'd be a miracle hahaI think just the oil pressure gain is worth the switch. Not sure about winter time. You may want to do some research on that. Good luck.
