2004 SRT10 Body Side Weatherstrips
Thanks. I tried Rock Auto but they only have the belt line weather strips and not the body side that mount to the body above the door opening. The body side weather strips also act as drip rails when the door is open and seal to the top part of the door when it is closed.
Best Regards,
Mike
Best Regards,
Mike
Try Precision Replacement parts
I'm sure this has been discussed many times but I am new here as I just got my 2004 SRT10 standard cab. Does anyone make the body side weather strips that are held in place by the windshield molding and get torn where they are contacted by the front door when the door shuts? I have tried all the normal places but keep finding that the part is discontinued. Any help would be greatly appreciated. Thank you, Mike
For my clarification is it these strips you're referring too? I'm still not clear - sorry and thanks!
Thank you so much for the TSB. I will begin hunting for these part numbers instead of the 55277190AB and 55277188AB.
Looks like one part number is for regular cab and the other for QC but there were no 2004 QC in the SRT line up - the TSB must cover all Ram series trucks back then
Good luck!
Good luck!
They are just Ram's anyway. There are only a small portion of the parts that are only for SRT-10 only
Does anyone have a need for the right hand body side weather stripping that runs up the "A" pillar and along the roof line and which acts as a drip rail in addition to sealing the top of the door, is a discontinued part and is always torn by the edge of the door when it closes? The Chrylser part number is 55277190AB. I have found a company that will manufacture them in small quantities in the same exact configuration as the Chrysler part with the redesigned lower portion that clears the door when closing.
No idea but Ill check mine
The QC strips are longer than the Standard Cab weatherstrips. You can use a QC weatherstrip on a standard cab by trimming the length. Unfortunately, the right hand weatherstrip is no longer available from Chrysler, Geno's Garage or any other source that I can find, and I have checked them all. I am exploring having a right-side body side (Roof Rail) weather strip made. Does anyone need one of the new type weather strips for the right side that has the built in clearance for the edge of the front door that always tears the old ones?
