Franko said:Hi:
Does anyone know what causes the shift from 2nd to 3rd (normal acceleration) to slip between shifts?
Bought new in Jan. and has always done it.
Thanks in advance,
Franko
Franko said:Hi:
Thanks. I did install that. Before the origional computer was doung the same thing in the 2nd to 3rd upshift and also constantly shifting in and out of overdrive (slight acceleration). On hard acceleration the 2/3 shift is fine.
The Stage 2 fixed that.
Thanks for the info,
Franko
fast fred said:from what i have been reading here and other sites is the kick down band for 2nd gear where not right form the getgo...bands on a lot of the 48res where just not done right from the start, mine was doing the same as yours slipping 2nd to 3rd and in & out of O D and kept getting more slipage and more till it cooked it ...i think you should take it in and get the bands ajusted ....(TAKE YOUR P C M OUT BEFORE TAKING IT TO THEM)...)if they keep slipping it will go bad at some time...that you can be sure of.....i just had mine redone from the dealer and it did not charge me a penny....
Viperpowered said:I keep hearing nothing but bad things on these automatic trannies with band adjustsments. It's also only on the 05's so far from what you people keep saying. I haven't read one thing about the 06 automatic's. Did they change the tranny in the 06's? Thanks.
Thanks. Is there any info that I can point the dealer to so he will know what I am talking about? (bulletin/recall)fast fred said:from what i have been reading here and other sites is the kick down band for 2nd gear where not right form the getgo...bands on a lot of the 48res where just not done right from the start, mine was doing the same as yours slipping 2nd to 3rd and in & out of O D and kept getting more slipage and more till it cooked it ...i think you should take it in and get the bands ajusted ....(TAKE YOUR P C M OUT BEFORE TAKING IT TO THEM)...)if they keep slipping it will go bad at some time...that you can be sure of.....i just had mine redone from the dealer and it did not charge me a penny....
DON'T TELL HIM ABOUT THIS PLACE...you don't want them to know of the mods ...i don't think there is a recall as it was not on all the 05's....i think some one was not doing thier job at the factory some where ok some not...Franko said:Thanks. Is there any info that I can point the dealer to so he will know what I am talking about? (bulletin/recall)
Thanks in advance,
Franko
FlyingLow said:Just get your bands adjusted. It is recommend at 15K miles anyway.
eddie102870 said:mine shifts fine, guess im lucky too.
