- Joined
- May 18, 2006
- Messages
- 34,027
- Reaction score
- 11,974
All plumbing should have access doors to get to that stuff.
I agree .. I have more freaking walls cut open in my home that carter has liver pills ... the freaking water here eats pipes and cause pin holes ,, I replace every bit of copper pipe above the slab over the years ... leaks destroyed my carpet and then I installed laminante and tile ... ive replace water heaters about every 6 years since 1998 .. all faucets and the one in the pics is now the second time .. Installed the filtering system a long time ago. Replaced bot toilets with a bucket dump system since the water eats the rubber flappers Water bill sky rockets if you dont catch it ) Never seen the likes of this crap anywhere else I lived ..... its happened to many homes in my neighborhood ... I also put shut offs at all faucets so I can isolate each incase of another leak . Otherwise I have to shut off the main water supply till its fixed .. What a joke when they built these dumps ...All plumbing should have access doors to get to that stuff.
I do to they always pop up when you least expect it ... Im glad I did modes with some stainless braided hoses ,, The water should now be supercharge hahahahaOMG!!! I hate plumbing issues! Nightmares in the waiting. Glad you got it fixed!
Maybe ,,I sure as heck dont drink itMaybe it's salt water hahaha
Chemicals from what Ive heard can damage pipes ....pull the trap . Easy work while you take a nap under the sink hahahaha !I want to clean the kitchen sink drain and can't figure out what to get in there to do it with. I found some pipe cleaner type brushes at harbor freight but i can't get a long enough one to get the lower part - thinking of some foaming cleaner still looking at options. Remove the drain pipe and cleab it out then reinstall but that's work lol
Yah that's what i was reading and i won't use chemicals they suck. Maybe some enzyme product. The trap was done a couple years ago that's probably the best way to goChemicals from what Ive heard can damage pipes ....pull the trap . Easy work while you take a nap under the sink hahahaha !
Heck I have a clean sink somewhere under all my dirty dishes hahaha ... check yhe garbage desposal hose ans make sure it clean or you may wonder where the smell and bugs are coming from hahahaha .. mine got clogged with cat food when I rinsed them off .. sink backed up ,, clogged drain hose ..fixed now
You may find your lost wedding ring in the clog hahahahaYah that's what i was reading and i won't use chemicals they suck. Maybe some enzyme product. The trap was done a couple years ago that's probably the best way to go
I've seen clogs that resemble tonsilsYou may find your lost wedding ring in the clog hahahaha
Esplain that one hahaha !I've seen clogs that resemble tonsils
My dad unclogged someone's drain and what he fished out of there was a gross blob - he said omg this looks like a tonsil. I've never seen one so i just believed him hahahaEsplain that one hahaha !
Open wide , shine a flash light in your mouth while looking in a mirror .... If you still have Tonsils your good to go hahahaha , if not your still good to go or maybe your dad removed yours hahahaMy dad unclogged someone's drain and what he fished out of there was a gross blob - he said omg this looks like a tonsil. I've never seen one so i just believed him hahaha
Happy belated Birthday Yellowfever
