Uhhh oh!!! lol if at first you don't succeed Try try again hahahahaGot to hot!!!
The prototype first editions are always worth the most!! lolPower still to high for this material at 75%
The jig is jaggin'!The fist one is so rough you can’t even run a cloth over it to clean it up, the last one is crazy smooth. I will have to work on the jig so it’s straight, and I still have a slight bend
I likeFirst and last
I love the colors on the first one! They all look greatSo far
That one will never happen, metal got to hot and warped. You also can’t simply wipe it off to clean it, it’s so rough it tears up the clothI love the colors on the first one! They all look great
Figures that would be the one I like! HahahahaThat one will never happen, metal got to hot and warped. You also can’t simply wipe it off to clean it, it’s so rough it tears up the cloth
It is getting closer , improving after every try .. the plan will come together , A-Team !So far
Picky picky hahahaFigures that would be the one I like! Hahahaha
Right?!!Picky picky hahaha
Well it’s come down to sourcing. I was looking for a specific size, I have no interest in cutting out plates, zero.What types of metal are those and what other types can be used ..maybe that dissipates heat better View attachment 68796
Burn water huh hahahahaThis is how most of my cooking projects turn out!!! Hahahaha!!
The learning curve at work ... looks like your getting real close !Well it’s come down to sourcing. I was looking for a specific size, I have no interest in cutting out plates, zero.
I have discovered that changing the frequency of the pulse rate reduces the warping, so I just need to find the right frequency, 50 gets me real close. Might go up a bit more and go back to multiple passes
Burn and warp! HahahahaBurn water huh hahahaha
Did the burn and melt a hole in a spagetti pot the first time iused it . I had just bought from Target .. The boiling water just vanished hahahaha !Burn and warp! Hahahaha
I don't care for LED lights but haven't experienced the problem you described. However in a house fixture they are to bright and harsh IMOJust ordered new headlights for the dakota and drivers and passenger side window switch bezel along with the overhead cover and dome light assy. For the 10 ..
Im looking for replacement tail light lenses for the dakota and possible the third brake light/ cargo light ... Mine doesnt have a cargo light from factory but appears its wired for them .. Ive been reading a ton of reviews on the LED ones and seems many have a problem with the lights staying on really dim and end up draining the battery over night ...thats not a problem I want to have !
Anyone have that happen or why that would happen when the power and truck is shut off ? Seems LED lights have goofy problems ... the ones I installed in my home flicker and becomes annoying so I change back to the incondecent bulbs .View attachment 68798
