2025 Project Post Ho Thread
Do home systems use 134A? I had no idea yikes!
Cars , trucks , refridgurators , home A/C , window and portable A/C units all,use 134a ... there are a few others I dont use and dont know if those will get banned or are !
Just like they did when they banned the R12 years ago they told everyone that the eniter systems needed expensive parts replace to be compatible ,, compressors etc .. t was a full blown kie back then .. from what i gathered later was that vacing the sytem to remove all the oil used in the R12 systems and replacing the recharging nipples was all that really need to be done .. many people were charge big bucks unknowingly before the truth came out ..
it appears it will be the same crap like then again this time .. big bucks to get you F'ed buy the EPA and the climate freaks .
Got the PCV VALVE and IAT sensor ..Installed both and test drove . Got rid of the rattle whistling sound from the PCV valve ! The truck even acceperates better replceing those , my bet the IAT was the improvement ! Checked codes ,, Still NONE !
IAT is original and appears retty filthy.
If I get those for my car will it acceperate better too?? That's important!! Hahahaha
All I can say is mine feels better changing the IAT and the others I replace helped also .. I didnt replace the 02 sensors but have them just in case or the MAP sensor .. Im still waiting for the IAC/ACI/CIA to get here hahahaha !
The plugs , cap , rotor and spark plug wires are n the way also !
I was mocking your spelling. Acceperate - lol
You do know if you type acceperate into the search it will say it means the exact same thing hahahaha....
More like the inadequasies of AI just being a over compensating asshat hahaha
Glad for no codes that Like getting a new vehicle!
Well that didnt last long hahahaha ,, got a new code this morning after a run around ... code 0455 ... so I jumped into my time machine and got to work on the Dakota ..
Make a smoke machine to find vaccum leaks ...
Spark plug in the Dakota ..
Old plugs dont look to bad , seem to be even burned ...
I broke the one and the other insulator is cracked . Maybe I did it or maybe not .. They were still firing good ..The gaps were between .55 to .57 and 1 at .60 ... the new plugs are gapped at .40 or close enough hahaha !
Next Plug wires , cap and rotor ...
I did find a cracked hose in the emmisions EVAP. BS .. might be the code That showed up yesterday .. 0455 code ..
They look good! Except the broken ones lol
Dakota gonna think it died and went to heaven when you're done!!
Yeah , their fine but mr arms took the brunt of the damage .. freaking blood thinners ..would stink if changing 6 plugs caused me to bleed out hahaha ..
Found a cracked evap hose so i ran to the parts store and bought some hose to replace the broken piece and to replace the PCV valve hose and crank case breather hose to the air intake .. 1 ft f each just incase I find some other vacumm hose on crack lol . Immhoping that cracked hose will get rid of the 0455 code ..
total cost of hoses $8.42 ,,, screw those factory hose and their insane prices .
