25.8 mpg
DevilDawg3097
Windy City
After the build and getting all the kinks out, she is running very nice, did a mpg test today, the best I have ever gotten was 21mpg now with alittle tweaks ;) avg mpg at 68-70 mph was 25.8 in 5th gear downshifted to 4th and cruised at 70 with mpg ranging 18-20 mpg:rock: a little too much traffic to check mpg in 6th. Wow is all I can say and to all the vendors thanks:D Sean,Stinker and Justin:burnout: now stop making me give you guys my money:marchmellow: :marchmellow:
Damn, that's good!
Are we talking Mazda or Nissan? No it is a Toyota huh? No damn way an SRT gets 25 are you joking. Shit I've been at 12.5 consistently. I know it's an Auto and QC but damn.
25.8 mpg you must have been drafting like a muther fker:D
Best Ive gotten is 21 down in Texas.
Please, tell us your secret.
In 6th gear on most rc's If I stress if you drive normal between 68-70 will net a 20mpg QC guys your just screwed cause 6gears is better then 4. Anyway the best I got with the s/c was 21mpg in 6th. Now with larger holes in the restricter plates, increase in flow thus better a/f ratios better burn in fuel. Dyno numbers to come. So it can be achieved if you take the lead plate out of your shoe:marchmellow: the 25mpg's was in 5th at about 68. So test in 6th to come. With a good tune that is also
My 04 rc stock has got a best 17mpg here in WV. We have no level roads!!! I usually get 12.5-13 off highway.
if you dont have an sct yet or a flash to the ecm I would suggest on getting one, makes a big differance.
The flash will improve fuel mileage? I am assuming the timing is tweaked? Tell me more and thank you.
TNVIPER said:
If you are using the truck's MPG readout it is wrong. The PCM flash will cause false readings....
that was used for just comparison, but I was on e so I decided to put only enough to get me to work, the guy looked at me funny when I only put in 2gallons of fuel, because I dont know how many know that are truck has only about a 1/2 gal reserve so when that light comes on it is time to get gas, but anyway the average came out to 25.8mpg. Would like to do it on a dyno and get it down perfect but I will waste the money in other ways more MODS:burnout:
Best way to check mileage is by filling the tank...drive at least 50 miles of city or hwy depending on what you want to check...refill at same pump...miles/gallons used.......try to do on the same day because weather conditions can change fuel volume..
I get 34 mpg At 80mph! I did that by parking the srt10 and buying a mini cooper.lol
My quad cab got 120 MPG...
It was on a trailer and I let it idle cause the battery was dead and needed recharging...:D...A hour and half later...the gas needle didn't move at all...:D :D
I found there is almost 1 mpg difference between using the onboard overhead and actually checking the mileage. The overhead is just for a rule of thumb. It is not correct even with the stock ecm. I always fill my truck and then refill after a complete tank of gas to be accurate. Check your truck like that and see if there is a difference. I know mine has only got 17 on the interstate so far. Like I said earlier, it gets somewhere in the 12-13 range off the interstate.
Everyone must also remember that the 04 came with 4.10 gears, which helps the MPG. The best I have ever got was 20 MPG at 65 MPH. Usually I go about 80 MPH, getting about 17 MPG.
Bill.
The best I got in mine before the 4.88 swap was 23.8. That is at 65-70 for two tanks of gas in 6th. Now the 4.88.......oh hell I don't even care!!!
