2500 RPM limit
Discussion in 'General Discussion' started by reboosted, Feb 2, 2019.
  1. reboosted
    reboosted Full Access Member
    78
    3
    Dec 24, 2016
    Houston TX
    OK. fresh plugs and it will rev to 4200ish. Its still way down on power though it definitely is making more. I pulled the rear O2 sensor on the drivers side. Not the sound I expected. Instead of sounding like an exhaust leak it was more of a leaking air hose sound, I'm staying away from the hissing viper jokes for now. I'll do more loud stuff tomorrow during daylight hours.
  2. reboosted
    78
    3
    Dec 24, 2016
    Houston TX
    Well today was a fiasco. Pulling the O2 sensor didn't help. I noticed the truck was back down to 3500 RPM and decided to pull the plugs again. The second plug on the drivers side (#3 in the firing order) was already starting to get dark. This is with less than 30 minutes of run time. The other 4 on the bank still looked new. I intended to do a leak down test but discovered my tester was busted. I do have a new one but will use it tomorrow. I think I will also pull the exhaust system and see if anything comes out of it. I'm also thinking of getting the injectors cleaned.
  3. THEWELSHM
    THEWELSHM Active Member Supporting Member
    2,389
    4
    Aug 29, 2008
    Brandon Florida
    Im going to tell my future grand kids about you mate...:) Man you are hard core focused... cudos to you..
    thewelshm
    ViperJeff likes this.
  4. shorty
    shorty Full Access Member
    2,015
    15
    Sep 1, 2012
    Emory, Texas
    Ha, ha, my friend, I am telling my 5 great-grand kids. Got the oldest his first toy Viper car---couldn't find an SRT-10.
    THEWELSHM likes this.
  5. reboosted
    78
    3
    Dec 24, 2016
    Houston TX
    Windchill near freezing today. Not that hardcore. Fuzzy slipper and fireplace mode.
  6. rottenronnie
    rottenronnie Active Member Supporting Member
    2,512
    21
    Jul 4, 2006
    Calgary, Alberta
    37 below zero here (Chilly). :turtle:
    Anyway, did you ever check to make sure you don't have a pinched wiring harness near the back of the passenger cylinder head?
  7. reboosted
    78
    3
    Dec 24, 2016
    Houston TX
    I did check the harness. Its in good condition. Did a leak down today. It was lower than I hoped but the engine was cold. They were consistent on all cylinders though. Had to turn the truck around in the garage so I replaced the one fouled plug and it ran OK but still not right. Hopefully I can get the exhaust off tomorrow.
  8. 505
    505 Full Access Member
    43
    8
    Sep 7, 2018
    Orlando
    So no CEL. Do you have access to something like a Snap On Scanner? My little POS code reader just reads / clears codes and turns off the light. But I'm pretty sure those higher level scanners can drill down much deeper into the PCM and will show parameters that are out of whack that won't throw the light for so many key cycles. I think the dealers use something called a DRB scanner and they monitor the truck running in real time. Seems like one side running rich is a big clue to something.
  9. reboosted
    78
    3
    Dec 24, 2016
    Houston TX
    I use a Bluetooth dongle with the Torque app on my cellphone. Unfortunately I have to have the expensive one ($100+) to communicate with my JDM engine (gen4 3sgte) swapped MR2. The cheapies just wont communicate with that ECU. This dongle got wet in hurricane Harvey but worked for at least another year. Torque can show a lot of parameters but it varies from manufacturer and model of vehicle. The truck recently set a code as I didn't have one of the injectors plugged all of the way in (oops). After fixing it and running the truck a few times the CEL went away.
  10. reboosted
    78
    3
    Dec 24, 2016
    Houston TX
    Turns out there was still some former front cat material in the drivers side pipe blocking the rear cat. After clearing it out the truck is running tremendously better now. It also stopped pushing oil out of the fill cap as well. Now to put some miles on it.
    TrailMix and ViperJeff like this.
  11. rottenronnie
    2,512
    21
    Jul 4, 2006
    Calgary, Alberta
    Great to hear.
    That would explain the dark plugs on one side, the crankcase pressure buildup and low power.
    "It always makes sense once you figure it out". :)
  12. Redtruck-VA
    Redtruck-VA New Member
    2
    Dec 22, 2015
    South Central Virginia
    Well done!
