Black1
I posted this on the Vette forums, but I know there are some "guru's" on here as well... so here goes.
_________________________________
Hello all,
I have a 1967 with a ZZ4 crate engine. I'm having a run-on (dieseling) problem. I was wondering if any of you had any ideas of how to stop it.
Here's what I have installed:
ZZ4 350ci GMPP crate engine
650cfm Demon carb (crate engine model)
MSD 6AL ignition box
MSD Pro Billet Distributor (tach-drive)
MSD Baster 2 coil
Stock GM (2 wire) distributor
Stock(ish) ignition relay box
I've installed the little capacitor supplied with the 6AL box. I went back and double checked that it was installed correctly (soldered in-line on the green wire (4th pin on the ignition box), and that the line on the cap was closer to the plug going to the alternator). ... This didn't solve the problem.
My timing is set to dead-nutz "0"... should I advance it and see if that helps?
The carb is running a little rich, but all the floats seem to be set properly and the car runs fine....
Any help or suggestions would be great.
Hello all,
MSD Baster 2 coil
