488 rearend change
Ironhead
h-town
ok so i am having a dealership here install my diff and 488 gear ,,they just called and said it is going to throw my speedometer and abs off a bit ,,can i get my sct tuner to set this up right ???
HELP STINKER....If they install the ring gear ABS sensor it will not affect anything Right????
didnt Grff put this in his ride ,,can you hit him up and see if he had to do something
Now your SCT tuner will not help any of this. All my ABS funtions are fine. The speedo I am not sure some say it is going to be off some say is going to not even change. To the best of my knowledge it did not change. Good Luck man you are going to love it!!!!!!!!!!!
No codes at all, I am not sure if they know what then are talking about. Get ahold of Ernie (IH8CHVY) He has a Viper tech friend that built mine and I beleive put his in for him.
Hey James, I have Ernie on the phone, he is going to find out for sure and call me right back. PM me your phone #
morning guys:D
yyyyaaaaaaaaaaawwwwwwwwwnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn
long night:p fixin to head home:marchmellow: but I havent heard of it affecting anyones speedo or abs, like Tnviper says , they are thinking old school, your sensor picks up a signal from the abs ring:D
Stinker said:
morning guys:D
You So Smart! :D
It will not effect your speedo or ABS;) I had the 4.88's done two years ago and not had a single problem:rock:
OK, Ernie just spoke to his Viper tech that set up his gear and Griffs gear and the guy said the ABS sensor parts are reused with the 4:88 gear and the ABS and the speedo will work fine. The only thing that will affect your speedo would be a different height tire which they can easily adjust at the dealership thru the computer. You need to call them and be sure they know what they are doing.
Yea what he said........:top:
Ironleg you gonna love that 4:88:rock:
it was a female service writer so that may be the problem i called them back and told her to slap that puppy on there
had to run out for a min jack sorry ,,,pm you number in case
I had 4.88's installed by Unitrax a couple of years ago and there was no problem.
