Chuck B
While I'm just shy of 100,000 miles officially I've gotten several requests to go over the history with my SRT10. I purchased 11/5/04 new from our very own Avondale Dodge here in Arizona. Patrick was still in High School back then...:rock:
I've done all my own maintenance though as you'll see I did have some warranty work completed. I'll be doing my 32nd oil/filter change in about 1000 miles (100,000) and have changed both the trans and diff oil every 10,000 miles. A bit overkill I know but I'd consider a combination of my driving style and higher temps here in Phx justify a bit more frequent maintenance.
13,700 - new Pirelli tires
13,700 - Warranty...passenger side AC warm. Dealer checked system...ok
15,092 - Warranty...new power steering pump. Dealer agreed to replace steering rack as well
15,092 - Warranty...Passenger side AC warm. Dealer added Freon. It helped.
28,480 - new Pirelli tires. Flushed brake and clutch fluid
29,230 - EBC green front pads. Factory pads were done. Rotors grooved and were turned
30,326 - Warranty...window weather strip replaced. clutch/brake pedal pads replaced due to wear
30,922 - Warranty...oil cooler lines
30,922 - Rear axle bearing bad. Axle gutted and rebuilt to new. Dealer had to obtain replacement axle from mexico factory
31,025 - Xmetal suspension and lots of billet parts
35,338 - Warranty...New steering rack. One seal began to leak
35,338 - Warranty...Oil cooler lines leaking
35,505 - Coolant flush
36,050 - New Goodyear tires (did a few race events)
40,866 - new spark plugs, flushed brakes and clutch fluid
44,143 - new optima battery
47,309 - 2 new Nikko tires (still doing race events),
47,309 - Front EBC pads, rotors are at limits so left them as is
49,255 - 2 new Nikko tires
49,255 - Power steering line leaking. Made up my own line (pre Stinker)
50,725 - Oil cooler lines leaking, Ended up building my own lines (pre stinker)
50,725 - Zeckhausen front rotors, front and rear pads. OEM rear rotors
51,261 - Permastar coated rims.
55,313 - New Yoko Prada tires (still doing race events)
55,402 - New inner fenders (F&R) Tires wore through all
63,901 - Tire replaced due to damage (3/8" bolt pierced tread)
70,887 - Flushed brake and clutch fluid, Flushed power steering, new coolant
71,077 - Trans output seal
81,947 - Trans output seal leaking again...sanded shaft with good results
87,164 - Serpentine belt and tensioner replaced
89,985 - Flushed brake and clutch fluid
90,686 - New Optima Battery
96,977 - Flushed brake and clutch fluid
100,000 miles will need the following:
*New tires - will go with Yoko's again
*New spark plugs
*New plug wires
*Coolant flush
*Zeckhausen front pads though still not at limits! Will turn rotors even though not heavily worn
*Power steering flush
My tire usage was high due to racing events I was participating in. While I've only done a couple since installing the Yoko's they are heads above anything I've used. Same for Zeckhausen brakes...heads better. Our high heat here kills battery's. Did you notice I'm still on factory original clutch? :rock:
Enjoy your SRT's. Mine is getting better as the miles rack up! :congrats:
*New spark plugs
*New plug wires
*Coolant flush
