6 speed tranny question
SRT2SLOW
Green Cove Springs, FL
What would cause fluid to come out of the vent tube at high rpm ? The tranny is not full. When I open the fill plug nothing comes out.
Lol hauling to much ass...
and no im not kidding.
I wouldn't doubt that. Flinging that fluid all over the place.
Or, the tranny is not breathing properly.
I have not experienced this but would suspect you need to change the trans oil. Probably foaming up to much.
the oil is not old. maybe 5000 miles on it and its right where it need to be
So either the oil is poor quality or a bad batch or the oil is boiling and that would be bad!! Go on a spirited run and then crawl under and check the tranny temp.
When you were putting oil in, did you fill it up enough so that it is over flowing? You're supposed to put oil in until it starts to dribble out.
I did. I filled it up through the shifter and when it started over flowing I out the shifter on.
I thought your supposed to fill it in the "fill" plug....
Might have put wayyyyy too much fluid in it E.
Only supposed to take 4 quarts
Yes you can fill through shifter as its easier but it should only be up to fill plug level. I think he said he filled till it came out fill plug?
