60 lb high impedance fuel injectors used
McLuvin said:
Cause the injectors are longer than the ones that came in my truck
like i told you via the pm ,i had these installed with my stock rails and no spacers,so i'm not sure why your injectors are somehow smaller
TNVIPER said:
I thought these were the shorts...same as OEM.....Clint did you raise the rails??
i had to raise the rail on my new injectors i just purchased :dontknow:
McLuvin said:
cha.. I don't either:dontknow:
i didn't originally install these injectors ,it was krc performance when he tuned my truck,i honestly dont remember there being any spacers installed,if you want your money back i'll be more than happy to refund it
McLuvin said:
The worst part is the connector isn't the same!!
the connector isnt the same?,ummm,i know for a fact the connectors weren't changed on my truck,are you the original owner of the truck,this doesn't make any sense
Shit, i need to check mine. I haven't compared my new ones to the old ones. Guess i should before i install them.
