Wanted to know if anyone has had this issue with their abs and brake light coming on. My brake light has been on for quite some time and when it first illuminated I had a computer hooked up and said it was my left front sensor. I bought an new oem sensor from the dealer and it didn't resolve the issue. I looked at all my connections and didn't find or see anything so I just figured I'd get around to it one day as the brakes still worked fine. Well recently I noticed that my rt front brake caliper started getting stuck and would cause my rotor to heat up quite good. It was periodical cause there were days where it wouldn't get stuck but then all of a sudden it would and heat the rotor up again. Well now my abs light illuminated and stayed on along with the already illuminated brake... And now seems my hub or both hubs have gone bad. I'm thinking that my rotors got so heated that the heat transferred to the hub bearings and sensors causing this issue. Any thoughts? Thanks
