ahhhhhh dropped push rod into the engine
Discussion in 'General Discussion' started by THEWELSHM, Sep 1, 2023.
Car Parts
  1. THEWELSHM
    THEWELSHM Well-Known Member Supporting Member
    2,445
    56
    Aug 29, 2008
    Brandon Florida
    So I'm down to reinstalling rods and rockers and I mistakenly dropped the push rod on number 10 inlet between the gasket and the block, I can see it with the remote camera and bought a bunch o magnetic tool. No luck yet, it's probably head back off deal, unless someone has a retrieval trick, any help would be appreciated.
    thewelshm
  2. Kiwi SRT10
    Kiwi SRT10 Well-Known Member Supporting Member
    983
    1,036
    Dec 16, 2019
    New Zealand
    Sorry I am no help. But I am sure if you give a big rev it will spit it out
    Wifey, Brat and THEWELSHM like this.
  3. rottenronnie
    3,961
    1,652
    Jul 4, 2006
    Calgary, Alberta
    I can't picture where your wayward pushrod is right now.
    The lifters are under the heads and there isn't room for much else, certainly not a pushrod.
    Anyway, confusion aside, those "flexible steel-claw grip tools" have been known to retrieve runaway parts.
    They are also great for removing those hard to reach nose-hairs.
    Good Luck
    Wifey, Brat and Kiwi SRT10 like this.
  4. THEWELSHM
    2,445
    56
    Aug 29, 2008
    Brandon Florida
    Push rod was wedged pretty good, pulled the head new gaskets on the way. Back to work on it next week.
    thewelshm
    Wifey likes this.
  5. rottenronnie
    3,961
    1,652
    Jul 4, 2006
    Calgary, Alberta
    Okay, finally I understand where that pushrod was hiding.
    THEWELSHM and Wifey like this.
  6. Wifey
    Wifey Well-Known Member
    23,172
    383
    May 18, 2006
    A picture is worth a thousand words!!!
    THEWELSHM likes this.
  7. Wifey
    23,172
    383
    May 18, 2006
    Good luck! It usually goes faster and better the second time around :eek:
