hey i have a set of mopar performance long tubes with catless mids coming in ,,,they dont have the extra hole for the a/f o2 sensor ,,,has anyone PUT a hole bung to install it ,,,and were did you get the insert to do it
the last time i did this i welded in a threaded nut that was 18x1.5mm thread, if i remember right......Ironhead said:hey i have a set of mopar performance long tubes with catless mids coming in ,,,they dont have the extra hole for the a/f o2 sensor ,,,has anyone PUT a hole bung to install it ,,,and were did you get the insert to do it![]()
Yellow venom said:I have 3 O2 bungs in both of my LT mopars,I just got the O2 bungs welded in and then screw in your sensors![]()
Ironhead said:from were did you get them or are you just bragging lol![]()
OSO said:I got some.
Headed to sealy sat., you ready to hit the track ?Ironhead said:i want two i plan on putting an a/f gauge on both banks ,,,,,ill trade you two trans housing tail end peices![]()
OSO said:Headed to sealy sat., you ready to hit the track ?
Haven't talked to anyone besides they all back out at the last minute anywayIronhead said:as long as i dont have to work ,,,since the beach thing aint going to happen i need to do a pass or two just to check a few things ,,,,i need a base before i try to spray the beatch and put the long tubes on ,,,i want to see the diff before and after:burnout: anyone else going ,,,???,,damn i got to hit the hay ,,,bell rings at 430 am ,,,i will call ya thursday after i get out of work![]()
