Alarm Issues
ccfeyh
Lancaster, Calif
Ok, the dealer says they can't find it so they can't fix it, it doesn't ever happen to them. Has anyone else ever had this going on?
I've had an 05 Hemi QC and the 10, both did this. I get up in the morning, and this only happens in cold weather. Hit the button to unlock the truck, open the door and the stinking alarm goes off.
Doesn't happen everytime, only every couple of weeks or so. But since I leave for work around 3:45 A.M. it pisses off the neighbors (next door neighbor is a prick, so who cares, it's the rest of them I care about).
I have the similar issue: sometimes the alarm goes off, and sometimes the remote start will start and then immediately stall. It automatically restarts and stalls over and over (it times-out after 4 or 5 times). It only does this when it's cold outside and only about every couple of weeks or so. Is this related? Is it a door switch, or is there a hood switch or something?
the door switch is integrated into the door latch. i have taken one apart to see what actually fails. i just know that that fixes the problem 90% of the time.
WOT your problem (if the module is aftermarket) might be the voltage sensing wire on the alarm module. When it gets really cold the volts / amps on the wire it uses to start the car can drop below 10 volts when started. If this happens the unit normally cuts off.:dontknow:
