Alarm outputs and factory Fob
VIPER BAZ UK
Is there a spare output on the OE alarm that i can use as a trigger to open the solenoid on the tonneau cover?
original remote was lost by previous owner and Snugtop no longer supply them
How are you all opening yours ?
Baz
Can you run the wire from the cover to one of the door latches? Might be worth a shot, I would worry about how much additional load it would put on the circuit.
VENOMOUS1 wired my tail gate lock to my door locks. When I open my doors the tail gate lock is also unlocked and when I lock my truck you can hear the tail gate lock. Should be the same on the lock on the cover. :rock:
Sorry.. I mean the truck has a solenoid fitted to the cover and when you press a remote (missing) it pops up to save using the key to unlock and lift.
Would like to wire this into the factory alarm so if I press the key fob twice it pops the cover..
Like said, run the wires to your door lock actuator wiring and you'll be golden.
I see what you mean, it's not actually a lock, it's a solenoid that opens the cover. That makes it a little more complicated.
That's correct yes... unlocks the cover and pops its up about 2"s ... On the Gen l Vipers there is a spare secondary output so when you double press the alarm fob it pops the door open first press turns the alarm off..
