Shadyscott999
Anyone know of an aftermarket source? I haven't been able to find one at NAPA or any of the other chains. I am scared to check with Dodge.
FATJACK said:If you can't find one at a decent price look around for a Alternator, starter rebuilder. Should have several in your area.
It can be repaired cheap.Shadyscott999 said:It is charging fine. The bearing is going out. It's getting hot and slinging grease everywhere.
Shadyscott999 said:Anyone know of an aftermarket source? I haven't been able to find one at NAPA or any of the other chains. I am scared to check with Dodge.![]()
wesalbert said:I've had good luck with local shops doing rebuilds. Most times actually increasing the output over a stock alternator. :dontknow: And ALOT cheaper.
This place rocks ( he-he )Shadyscott999 said:Thanks guys. I will look for a local re-builder tomorrow. Sounds like that may be the way to go. Maybe I will have better luck than last time.
Scott try local to find a shop usually they can fix them for $50 or less, if ya cant find one, hollar, got one here local , the guy is great:rock:Shadyscott999 said:Anyone know of an aftermarket source? I haven't been able to find one at NAPA or any of the other chains. I am scared to check with Dodge.![]()
