Relates to Stinker's oil lines: for the adapter fittings and hose fittings -- what torque should the fittings and hose ends be torqued to? Also, is there a socket or technique that can be used to torque down the adapter fittings without damaging or scratching the finish? For the hose end fittings, I talked with my local spedd shop and they suggest hand tightening (how tight is tight?) and using a -10 AN wrench tighten the hose ends another 1/4 to 1/2 turn. Or should I just throw out all the analysis, tighten 'em up 'till their snug and then check for leaks and retighten as required?
