auto tranny oil capacity
Yellow venom
Boosted Venom
Edmonton,Alberta,Canada
How much oil does the auto tranny hold with an empty TQ and all lines and cooler blown out,so completely empty?:dontknow:
With a deeper pan mine took 17 quarts completely empty. So stock should be close to 13-15 quarts. But if you are just draining it straight from the truck, you will need even less. Don't know if this helps you or not?
Mine was somewhere around 18-20 when I put in a dry suncoast and converter. I lost track because I thougt I was done, but it evidently hadn't all circulated yet, so I'd add another, wait, add, wait, etc.
buy two cases and what you dont use you will have left over for the next time you change it.
These numbers are for an 06 not sure if the differ in the 05
Service Fill - 48RE 3.8 L (4.0 qts.)
Overhaul - 48RE 14-16L (29-33 pts.)
