spry
I've been having some driveline vibrations in the QC after the 6-Speed swap, and have been thinking it's my driveline angle. I found a great article on Pirate4x4 (Pirate4x4.Com - Extreme Four Wheel Drive) for measuring angles, and this is what I came up with. I mainly used this picture (before calculating for cruise throttle). http://www.pirate4x4.com/tech/billavista/PR-shaft/worksheet sc.jpg
My QC has a JTSVP 2/5 kit, a t56, a JTSVP billet kicker shock, a single piece driveshaft, and possible Caltracs in the future. Upon measuring angles, I am currently at (in Degrees): Front 4.5 down, Rear 4 Down, Driveshaft 1 Down. Therefore, by my calculations, my angle at rest is .5 Down.
My vibrations seem to happen on the highway, especially when passing other cars. I believe this has something to do with my angle at cruise throttle. According to the article, the angle changes around 2 Degrees when cruising. Therefore, my angle at cruise throttle is 1.5 Degrees up. I could only imagine what the angle is at full throttle at highway speeds.
In order to straighten out the driveline angle at cruise I will be installing a 2 Degree shim. My question is, does it make sense to install a 4 Degree shim to compensate for further axle wrap upon acceleration?
