mosrt10
Just got my b&m shifter in and I need to know if I can use the factory hurst shifter handle on top the shifter? I really am a little anal when it comes to keeping the truck looking factory.
Sorry man, I thought you were asking about the shifter ball on top. I am not sure about the chrome lever. I didn't try it. :dontknow:mosrt10 said:do you mean the shift knob or the chrome hurst shift lever?
If your talking about the shifter ball, yes it will screw right onto the black B&M shifter arm. If your talking about using the Hurst shifter arm on the B&M base, I don't think so. Didn't really try it but the B&M base is threaded whereas the Hurst base just had holes for the rubber isolator bolts to pass through. If the holes in the polished Hurst arm line up with the holes in the B&M base then perhaps something could be rigged up. I'll do some investigating this weekend.mosrt10 said:Just got my b&m shifter in and I need to know if I can use the factory Hurst shifter handle on top the shifter? I really am a little anal when it comes to keeping the truck looking factory.
Excellent work. I might have to do that myself. :rock:spdrcrj said:I have the B&M and, no, you cannot use the Hurst handle. However, I used a metal brush wheel on a bench grinder and removed the black anodization. Then used Never dull and polished the arm up. Looks stock, except it says B&M instead of Hurst. Standby...I'll post a pic.......
Jim
