toofast_28
Anyone know where I can get a B&M shifter? Checked B&M website its not listed? or a comparable shifter that will get the 2-3 shift correct?
JTS VENOM PERFORMANCE said:BM no longer makes the shifter, summit has a few left
05QCSRT10 said:
ZCx said:got mine from Hurst-Shifters for $189.:rock: :rock: :rock:
ships as fast as Stinker & if ya need anything Hurst looks like he has it:rock:
toofast_28 said:you bought a B&M from hurst???
toofast_28 said:Anyone know what the thread size is on the B&M shifter?
Nope, but you can drill out the Hurst lever and make it work (not perfect but will work)hcetzneb said:does the factory shift ball fit on the b&m?? Also the shift arm ( the black arm in the b&m kit) looks the same as the upper part of the factory shifter are they the same interchangeable ?? i like the one that says hurst better
toofast_28 said:I ordered a black 8 ball with flames, and a skull in the top of it for the shift knob of the '49 SRT-10 Chevy on top of the B&M shifter. check it out.
ZCx said::rock: :rock: :rock: :rock:
