Snakes709
OK the other day i decided to change the fluid and adjust my bands. However at the time i wasnt able to get to the front one so i didnt touch that one. I did the rear but was in a rush and forgot to back the band off 3 turns after torquing it to 72in-lbs. I went for a quick drive and thats when i noticed i forgot that step. The truck was bucking like crazy, locking the tranny/driveshaft up and chirping the tires...turned right around and parked the truck...maybe 150 meters total distance driven.
So the next day i dropped the pan again and re-adjusted the rear band...ok good, now the truck is driveable...but it had a really bad 1-2 slippage...i messed with the cable going to the TB a few times but couldnt get it to stop, got my shift points perfect but that was screwy.
So today i dropped the pan again, made damn sure i torqued it to the right specs and backed it off 2 turns instead of 3 (thinking it would put more pressure on the drum and stop the slippage) Also i was able to get to the front band and got that adjusted to specs.
Took a drive around the block....still slipping in 1-2. WTF is going on?
Here is a video of it, i know its hard to see but at 2100rpm it shifts from 1st to 2nd and then right away the rpms flare up.
Do you think i damaged something when i fucked up the first time?
