Anyone that has moved their battery to the rear of the truck... Have you had any problems with slow starting? Thinking about doing it soon along with radiator overflow and washer res to clean up the bay.
Unless JMB started using a thicker cable then yeah it'll turn over a little slow, I've had mine for about 2 years with no problems. My truck sits A LOT so my battery has trouble after its been sitting but after driving the truck for a little bit it charges back up. I'd buy the kit again and wouldn't worry about the cables, if you're making your own setup the I would go ahead and use thicker cables.
I know the trucks are different, but I have one on my Dakota and I have never had problems with it. Got the kit from Summit. Run a new positive wire and ran the ground wire out the bottom of the bed to the frame. Works great.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
