Ok, just pulled the radiation suit off...LOL--you wouldn't believe how long it took to get all the bugs off the bottom! Tony, when I talked to you earlier, and mentioned I had 2 hours left, it turned into 4. By the time I got everything buttoned up and secure, it was 6:00.
So, everything is done. However I got scared to death when I started the truck and white smoke started coming out of the tailpipe. I guess all that newness had to burn off. The strangest thing is that the truck seems quiter not only at idle, but also wide open throttle. The other noticeable difference is how quickly the truck now builds rpm's
Still not sure about tomorrow. The instructions for the headers say that you should put 500 miles on the computer before you dyno or run the truck overly hard, and if I go to the track tomorrow, that's exactly what I will do. I also want to make sure that for some freak reason, my CEL doesn't comes on.
As for the install, make sure you feed them from the bottom! Sure works much better. The best part was the mids, they come in two pieces per side, and they fit with the existing pipework perfectly. The clamps that they sent weren't real great, but other than that, I'm very pleased
