Belts
LORD CHAVEZ
Irving, Tx
Something is makin a loud noise when i start it up on cold mornings. Does it for a lil bit. Thinkin mite be the belts. Is it something i should be worried about or not.
An abnormal noise is the truck telling you it needs attention. Get it fixed before it becomes a more serious issue. Could be the belts or a pulley, idler pulley or tensioner are a good possibility.
I changed tensioner pully before but it only does it on really cold days and goes away after about 20-30 seconds
My tensioner went out one morning... what a horrid clank clank clank. I made a post here and posted a vid on youtube about it.
See if that sound is the same?
It is most probably the oil filter. The 04's have a oil pressure spring issue and it makes a squealing noise at startup. most buy the viper oil filter to minimize the squeal. I just live with it. Watch your oil pressure! some have split the oil filter and made a hell of a mess! The oil pressure spring assembly can be changed out to the 06 model if you start having over pressure issues.
Crapola, I got cheated on my truck. I just got 1 (one) belt. Reckon VENOMOUS1 heisted the rest of them? :dontknow:
