best intake
VIPER said:
im jealous :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
I'm jealous of your timeslips:eek: :D
Slap a blower on that bad boy, knock 1/2 second off your 1/4mile time, and beat the record:rock:
DECEMBER - the Roe will go on :D :D :D
i just dont have the $$ ATM
VIPER said:
i cant say - my wife might be looking ;)
:elefant: :elefant: :elefant: :rock: :rock: :rock: We have another contender for the record!!!:burnout:
How much are you gonna be spraying through the Roe?
after the rebuild and Roe TSTM it should handle 250 to a full 300 shot if not more the way i spec'd it was 425 shot - not sure if i want to spray that much
Damn dude:D You'll be deep in the 10's:rock:
only time will tell :D im not sure about a record but it will be crazy fast
No reason you can't take the record with that set up:rock: Start a thread when you get this going... gonna be badass:D
JTS VENOM PERFORMANCE said:
the only record he is gonna make is to the buffet table:p
probley buddy :D :D :D
i need to give ya a call a little later if that is OK
Vman455 said:
I've heard this said many times, but I'm not sure I buy it entirely. The reason is: the Gen I and II Vipers came with flexible, ribbed intake tubing (like the trucks, only smaller) from the factory, except for ACRs which had rigid, smooth tubes and K&N filters. Those smooth tubes and filters were enough to certify the engine for 10 more horsepower and ft-lbs, and smooth tubes are commonly one of the first mods for owners now. When I look at a stock intake on a Ram SRT-10, I see a giant version of the stock intake tubes on a Gen II, with pleats and creases all over the place. Is there really nothing to be gained by smoothing the airflow through there?
Dont matter how smooth the tube is if the air flowing thru it is hot....the stock box will keep the temps 10-50 degrees cooler....click link below for some discussion about "CAI"....
http://kennebell.net/techinfo/general-info/HotAirWARNING.pdf
