Boomer lowering Kit Question...
BOOMER said:
eventually i will make a kit that can relocate the tierod end to keep them at the same angle as the control arm. until then we have a urethane spacer that goes under the springs to lift the front end up a bit to control the bumpsteer, and instructions and the kit to adjust the rear height so you can level the ride height to your preference. the 06's are critical onm alignment, so make sure you give your self enough adjustment room on control arm
Gary, I was never informed of any urethane spacer:dontknow:
How far does the front need to come up to take care of this problem?
Gary I can give you the part # of the bump steer kit I used and made work , hollar if ya need it, You could remachine it alot easier than I could:D
hell yea, pm me, my stinky brotha:D
Chuck B said:
Installing SC?! Need anymore help? Heck, I can even a turn a wrench or two!
I will be happy to accept any help anyone wishes to provide.. I am supplying the pizza and beer!!
" and instructions and the kit to adjust the rear height so you can level the ride height to your preference. "
Is this just for the 06 , or the 04-05's as well ? I would like mine a bit lower in the rear (about 1")
its only for the 06 quad cab, not the rc
qc's only
