PDR-GUY
BOOMER said:eventually i will make a kit that can relocate the tierod end to keep them at the same angle as the control arm. until then we have a urethane spacer that goes under the springs to lift the front end up a bit to control the bumpsteer, and instructions and the kit to adjust the rear height so you can level the ride height to your preference. the 06's are critical onm alignment, so make sure you give your self enough adjustment room on control arm
Gary, I was never informed of any urethane spacer:dontknow:
How far does the front need to come up to take care of this problem?
