What is the highest boost level that is being run on stock engines and forged ones?
Stinker said:Need to keep ya boost under 10lbs on a sc'r , probably less than 8 on a turbo, they act differently, but unless you replaced the rods still dont push it, if a piston let go, more than likely it may have damaged the rod, hopefully you had the rod double checked, but the late 04 and on rods wwere barely good for 700 rear wheel.
FlyingLow said:Just didn't have to funds to do the rods so I'm trying to figure out what level to set the boost to. I think the Rods but I would have to ask Marty. What are the stock rods limits? Is it boost level or HP?
blackviper said:I'm running a solid 10 lbs on stock internals. Either I've been lucky so far or that is probably the max. My crankshaft horsepower should be somwhere around 720 if you take my STD numbers. I will be doing forged internals and ported heads soon. I don't want to continue to gamble. Once the build is done I will turn up the boost some more, maybe 12 or 14 lbs.
TNVIPER said:George let me know when you have the smaller pulley machined...maybe we both can save money doing 2 at 1 time?..:dontknow:
kyle's srt10 said:I have plenty to go around if I can't get a hold of that certain someone![]()
Stinker said:Man Flyn low I dont really know what to tell ya, but I would get a decent number and jsut stay there with a safe tune.
